Blaze does not sync
Just bought a second hand Blaze and it will not connect to my Samsung S7 Edge. I get all the way through, even putting the passcode in, but it then does not sync. I have reset multiple times, reinstalled the app 3 times, Bluetooth on and off and it still does not work?
1 REPLY 1
It's great to welcome you @SimonWi.
Thanks for troubleshooting this by yourself. If you are having issues syncing your Blaze, I recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
I hope this helps, let me know the outcome. Robot Happy
