11-22-2016
06:05
18:56
DavideFitbit
11-22-2016
06:05
18:56
DavideFitbit
This is my second email for help.
I have tried every single advise listed previously and the app is just not syncing.
Moderator edit: format
Best Answer11-22-2016 06:31
11-22-2016 06:31
Was one of the things you tried a restart of the Blaze? If so, how many times did you try it? It's known to not always work so needs to be tried several times. Here's the process in case you haven't tried it:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Best Answer11-22-2016 06:43
11-22-2016 06:43
Sorry @Shollay without knowing what everything you tried, and not knowing what device you sync through puts us at a disadvantage.
I'm assuming this problem recently started.
Steps to try, with a forced sync after each.
I cant think of much more. But check out the help doc
Best Answer11-22-2016 18:27
11-22-2016 18:27
I am having the same trouble with mine. I called and they ended up sending me a new pebble and it won't even let me set up the new pebble!
11-22-2016 20:43
11-22-2016 20:43
Best Answer11-23-2016 03:52
11-23-2016 03:52
Welcome to the Community @purdystephanie, @Shollay it's great to see you around and thanks for troubleshooting this inconvenience by yourselves. @Rich_Laue and @SteveH thanks for stopping by and the tips provided.
If your trackers are not syncing, I recommend following @HelenaFitbit's instructions in the Having trouble syncing? post. After these steps your trackers should sync without an inconvenience. Now, if you have already tried these steps without success, feel free to get in touch with our support team, for a faster response you can contact them via phone or chat.
Let me know the outcome. ![]()
Best Answer11-23-2016 04:33
11-23-2016 04:33
11-23-2016 04:51
