11-22-2016 22:00
11-22-2016 22:00
My Fitbit Blaze screen blinks (never happened before) when I lifted up my wrist and at the same time, i noticed the battery drains out in a day.
Anyone had the same problem before?
Best Answer11-23-2016 03:49
11-23-2016 03:49
Welcome to the Community @darrencyf. If your tracker's display is not working properly. I recommend restarting your Blaze. About the battery inconvenience, please check this post, where you will be able to find some steps regarding this inconvenience.
Let me know the outcome. ![]()
Best Answer11-23-2016 04:12
11-23-2016 04:12
Best Answer11-23-2016 04:49
11-23-2016 04:49
Thanks for the information @darrencyf. At this point, I recommend getting in touch directly with our support team for further instructions. For a faster response you can contact them via phone or chat.
Catch you later. ![]()
