Brand new, has been correctly aligned, cradle snaps shut and have tried 5 ports on 2 computers to charge it and it is just a blank screen. Have tried to reset and it flashes a large battery with little charge then goes blank again. Tried to set it up and I keep getting a message that the fitbit doesn't have enough charge to do it. Help please.
Best AnswerHi, it should be charging even though it's not saying it's charging, some people posted that they had success with that.
If you just bypass the battery too low message and click continue to keep setting up, it does eventually get through the setup and do the update even if the warning: battery is too low, is on. That's the only way I was able to get mine set up.
I hope it works for you!
K
Best Answer@Karplop I've tried to do that a couple times and when I get to the end it still says the battery is too low to update. Do you know if it will charge if not setup?
K
Best AnswerThank you so much, this did work for me.
Best Answer@kcallan17 when you connected the tracker up to charge it, did you feel a vibration? This is what will tell you that it is charging.
