08-01-2017
10:52
06:24
AlejandraFitbit
08-01-2017
10:52
06:24
AlejandraFitbit
I've just bought a Fitbit Blaze and it won't charge, anyone else had this problem?
Welcome to the forums!
Did you try a different USB port on your computer?
If so then take it back and exchange it where ever you bought it
If here contact support. Use the help link at the top of the forum
Wendy | CA | Moto G6 Android
Best AnswerDod you feel a vibration that tells you that it is charging when plugging it in?
Welcome to the Community @Cate46, @WendyB and @Rich_Laue thanks for stopping by.
If your tracker is not charging, I recommend restarting your Blaze. After the restart process, I recommend following the instructions provided in this post.
I hope this helps, let me know the outcome. ![]()
