01-28-2018 08:53
01-28-2018 08:53
My Blaze is clicked into the charger but the picture of the battery does not come up. Just started having this issue. Very frustrated. 😕
01-28-2018 10:50
01-28-2018 10:50
You will not see anything until its set up. Leave in the charger for 2 hours and then set it up using these instructions
http://help.fitbit.com/articles/en_US/Help_article/1873
Wendy | CA | Moto G6 Android
Best Answer01-28-2018 15:51
01-28-2018 15:51
I am having the same problem. It has been on the charger for a few hours and still not displaying anything. When I try to sync with the app, it just says “looking”.
Best Answer02-01-2018 03:56
02-01-2018 03:56
Hello, I had similar trouble, I charging my device always using the power adapter( like cellphone power adapter) by wall outlet and 3 days ago my device stopped charger and Now only get charger using Computer USB port and the battery life its better than charging by wall outlet.
Hugs and cheers from Brazil
Tiago
Best Answer02-05-2018 04:27
02-05-2018 04:27
Are the contacts clean?
