03-20-2016 14:13
03-20-2016 14:13
The blaze advertises a 5 day battery. When I orginially got it, it would last 2-3, which I thought was no big deal because I played with it alot. However, the last week or so my battery seems to be draining. Yesterday I let it fully charged and have made it a point to not play with it excessively since it was charged. It has been about 20 hours and I have < 1/4th battery remaining. Is there something going on in the background that is just draining my battery? I didnt pay this much to charge my watch daily and I can't find why the battery won't last.
10-15-2018
07:32
07:04
10-15-2018
07:32
07:04
Hello everyone.
I am sorry to hear about the battery issues you all are experiencing with your trackers. If you have already tried the instructions provide in this post and keep having battery issues, I suggest getting in touch directly with our support team. For a faster response you can contact them via chat.
Catch you later. ![]()
Best Answer10-15-2018 09:44
10-15-2018 09:44
10-18-2018 13:26
10-18-2018 13:26
Haven't noticed? Did you read through this thread? Seems like a pretty good example of selective learning.
10-18-2018 13:59
10-18-2018 13:59
i would suggest calling fitbit "support" immediately...all the chat is doing is tic-tic-ticking your warranty away...escalate to a manager and raise Hell!!
You should be able to receive a new one within warranty. Downside: now you have another
new faulty Fitbit product as THEY HAVE DONE NOTHING TO FIX THE PROBLEM WITH THE BATTERY---IT IS NEGLIGENCE!!....fyi you don't get a new warranty with the new fitbit so beware when it goes bad, as it WILL go bad.
I don't even think AlejandraFitbit is a real person--stock photo!...the same cookie cutter answer for every complaint. At some point Fitbit will be out of business or fix this issue.
GOOD LUCK
10-19-2018
09:12
06:43
10-19-2018
09:12
06:43
Thanks for your participation in the Community @jetfan214, @mfley and @tbird0013.
Upon checking with our support team, I was told that you have already created cases with them. I know that they will be glad to help you out and provide you a solution. If there is anything else we can help you with, do not hesitate to post it.
Best Answer10-19-2018 09:25
10-19-2018 09:25
10-19-2018 09:34
10-19-2018 09:34
Yes I did. The answer to me was to sync it to another device. Which does not help when 1. I do not have another device and 2. The point of upgrading to this was so I would get the notification of my messages and calls. Seems like a stupid solution. They also said they were aware of the issue and working to resolve it. Which they told me 6 months ago.
10-19-2018
14:34
08:12
AlejandraFitbit
10-19-2018
14:34
08:12
AlejandraFitbit
I'm sorry, but there was no solution provided. They said that because the fitbit was already replaced once they'd offer me free shipping on a new fitbit. That's hardly a solution. Not your fault, I know, but the fitbit customer service sometimes feels lacking.
Moderator edit: removed personal info
10-22-2018
08:17
06:09
10-22-2018
08:17
06:09
I appreciate you getting back to us @mfley, @jetfan214 and @GuyGene.
Thanks for the feedback provided about the battery issue you were experiencing, if you haven't checked our warranty policy, you can click here to see it.
Now @GuyGene about the syncing problem you are having, I recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
see you around. ![]()
Best Answer11-14-2018 05:19
11-14-2018 05:19
Mine is not holding a charge and never has more than a couple day, now less than 24. It is my alarm because the vibraction in the alarm is less invassive than my ph. It is dead middle of night unless i put it on the charger before bed. Frustrating. It is not syncing well either. It was an expensive investment to last such a short time. . Seems it would have been made to easily replace the rechargeable battery as they do not last forever.
11-22-2018 08:16
11-22-2018 08:16
I think I have found the solution to this problem.
Go to settings on your blaze, not on the computer.
Invoke a shutdown/restart on the blaze watch itself.
Then recharge your blaze.
I believe when not restarted this way for a long time, the watch runs algorithms internally in a LOOP and use up the battery really fast.
12-08-2018 11:29
12-08-2018 11:29
That was the solution! Awesome suggestion! I literally stopped using the watch until I read your post. It is now keeping a charge for 4-5 days. Prior to reading your post it would keep a charge for 14 hours.
Thank you!!
12-08-2018 12:21
12-08-2018 12:21
Same here!
@Bogu wrote:That was the solution! Awesome suggestion! I literally stopped using the watch until I read your post. It is now keeping a charge for 4-5 days. Prior to reading your post it would keep a charge for 14 hours.
Thank you!!
12-11-2018 14:01
12-11-2018 14:01
12-19-2018 08:51
12-19-2018 08:51
There are 2 ways to reboot your blaze:
1. on your blaze watch, go to settings and shutdown the watch.
2. press down the lower right button and the left button simultaneously, and hold until the watch will restart by showing the fitbit icon. Holding the button takes a few seconds, be patient. Wait for the fitbit logo to show up, meaning reboot.
3. Do a reboot before charging your blaze.
12-19-2018 13:05
12-19-2018 13:05
Well unfortunately I am having the same problem. Charge overnight and it lasts about 30 hours. Have turned everything off and it makes no difference. I've had since last Christmas and am not a happy camper my daughter got me this for Christmas and paid too much in my humble opinion. Has anyone had any luck fixing this problem?
Best Answer12-19-2018 14:23
12-19-2018 14:23
12-19-2018 16:51
12-19-2018 16:51
12-19-2018 19:37
12-19-2018 19:37
I loved my FitBit - WHEN it worked. The sad part is that when the battery could no longer hold a charge I got a lot of BS solutions that didn't work. They dont seem to care that people spend $100's of dollars on their product and they simply blame your phone or offer a discount if you spend more cash.
Horrible customer experiences will be the end of FitBit.
My new watch works great, but if I post its name the will delete my post - AGAIN
Censorship at it's best.
My cell phone company makes a watch that is out of this world, the best in the entire galaxy as far as I'm concerned. And it's on sale for another 3 weeks. Only 46mm too!
06-03-2019 10:33
06-03-2019 10:33
I love my Blaze and use it every day. But now over the past 3 days, it won't hold a charge for more than 3 hours. I noticed it was dead on Friday after charging it on Wednesday. Then after overnight charges, it would be dead again during the days on Saturday and Sunday, including multiple dead batteries and charges during the days on Saturday and Sunday. It is now Monday and I tried the reset and the other recommendations, but nothing is working. I have a Blaze version 17.8.40.2. I tried the shutdown from the watch with a recharge afterwards, but then the Blaze just died after 3 hours. My guess is since this is not a gradual battery degradation and a sudden loss of life that there was a bad firmware push. Since the iOS App version was updated to version 2.94 a week ago, I'm thinking it is tied in with that. Fitbit - PLEASE HELP!!!
