09-10-2017
04:56
07:14
AlejandraFitbit
09-10-2017
04:56
07:14
AlejandraFitbit
My Fitbit Blaze fell and dropped on the floor. Now it isn't working. What can I do?
Hi @Cepociute - Is it doing anything? I'd try a restart to see if that works - see below. If not, check with customer support. Good luck!
It's great to welcome you @Cepociute and @Ozzie65 thanks for stopping by.
I would like to know if you keep having issues with your Blaze? Did you try the restart procedure? If you didn't, I recommend restarting your Blaze. Also, is it responding at the moment of placing it into the cradle?
Hope to hear from you soon. ![]()
Thanks for the information @Cepociute. Since the troubleshoot provided didn't work, I recommend keeping an eye on your inbox for further instructions.
See you around. ![]()
