11-08-2020 21:14
11-08-2020 21:14
In the last week my blaze has been discharging from a full charge to zero in about two hours as opposed to several days. I have read similar comments on here and have cleaned the contacts and other suggested remedies but to no avail. Is it possible for me to log a fault or speak to an engineer - it is very frustrating as I haven’t exposed the blaze to water or violently jolted it so I’m perplexed as to why it has suddenly started doing this.
11-22-2020 21:04
11-22-2020 21:04
You could contact Fitbit, however they do not replace batteries.
Or open Google and search for Blaze Battery Replacement, you will find a source for the battery and several videos on the process to replace it. Their probably also is a company that will do this for you.
Best Answer11-09-2020 08:00
11-09-2020 08:00
Mine has the same problem. It is very annoying and makes me want to get a different brand of smartwatch.
Best Answer11-09-2020 08:15
11-09-2020 08:15
Best Answer11-09-2020 15:21
11-09-2020 15:21
Mine has worked well until two days ago when I had the same issue, can the battery be replaced?
Best Answer11-22-2020 21:04
11-22-2020 21:04
Best Answer11-22-2020 21:51
11-22-2020 21:51
