@FerdinandFitbit The last 4 versions of the android app have had a ton of problems syncing. I've done all the recommended troubleshooting and it's still a problem. The very latest version is mostly OK, but it will sometimes say that it synced, but it didn't get all the data, then it will start again, but the bar won't go anywhere. I can always tell it's a problem because the "big" stat in the middle of the screen changes from steps. I can kill the app and sync again and it's usually fine, except that it for some reason has started logging me out when I kill the app.
Things I've tried:
1) Restart phone
2) Restart Blaze
3) Remove Blaze and setup as new device
4) Different Blaze
Because I haven't been able to sync with my PC for almost 1.5 years, this is really a problem.
10:33
09:02
05-24-2017
10:33
09:02
Hi @MagCoop. Great to see you in the Forums and thanks for taking the time to share this with us!
I'm pretty sure that many users will find your advise helpful!
Anything else you may need, let me know!
@meresydotes, Thanks for taking the time to share your feedback on this. I'm very sorry that you're having this many iddues with your tracker not syncing. I'll be sure to pass this along to our team for them to take a look and hopefully get a solution for it.
Best AnswerI just got my blaze and was having this issue. The following is what I ended up doing and it seems to be working now.
1) removed my Charge 2 from Bluetooth pairing
2) removed my charge 2 from fitbit application
3) removed Blaze from Fitbit application
4) removed Fitbit application from my phone
5) restarted my phone
6) reinstalled the application
7) added the Blaze back in the Fitbit application
😎 confirmed it was paired with phone
it has been syncing since. Also had issue getting notifications until I removed the Charge 2. Seems to get confused with 2 devices setup.
Hope this helps.
Best AnswerFinally updated it's firmware after 10 attempts, synced twice, never synced again. On its way back for a refund. Wasted SO MUCH time. No more Fitbit for me.
