Hello.
I have a Blaze version 17.8.402.1
It has been working great for months. Today I booted it up and it will not reset my stats from yesterday to a clean slate today.
Ive tried to remove the blaze from my iPhone Fitbit app twice setting it up as a new Blaze but the data from yesterday persists.
Im at a loss on what to do.
Thanks.
Best AnswerYou say that you booted it up, @GLevinePDX does that mean that you turrnThthe Blaze off at night? If so then that is the cause of the failure to reset the data at the end of the day.
Why does this ocaisionaly happen? ImI'not sure. but having to sync every morning to set the time would bother me.
Best AnswerHello Rich.
Yes I power down all my tech at night. Just a habit I guess. So if I’m hearing you right you’re saying I wouldn’t experience this issue if I left my Fitbit on all the time?
Ironically when i turned it on today and synced it with the iPhone app it worked as it always has.
Best AnswerIn general I would say yes @GLevinePDX.
While most nights the steps get reset when the tracker is turned off. there are a lot of posts that say that occasionally this is not so.
