01-03-2017 00:34
01-03-2017 00:34
Since recieving my Blaze on the 31st Dec, after 1 day I have been unable to sync my blaze with my handset. I've unpaired and paired both devices, rebooted my blaze tracker and uninstalled the fitbit app to install it again. All of which has still not resolved the problem! For a high tech gadget foe that price, these problems should not be happening. Very frustrating!!!!
Best Answer01-03-2017 01:18
01-03-2017 01:18
Hi, @Gratz, have you checked whether your handset is a supported device?
Best Answer01-03-2017 01:33
01-03-2017 01:33
It is! I have a samsung S6.
Best Answer01-03-2017 02:02
01-03-2017 02:02
Hi, @Gratz, can you check with to make sure that you have the latest version of the app? It should be 2.39.1 . Also you will need to have location services turned on.
You might also want to check this sync troubleshooting help.
Best Answer01-03-2017 04:58
01-03-2017 04:58
Best Answer01-03-2017 05:00
01-03-2017 05:00
Hi, @Gratz, that's the best plan if you haven't found any solutions. Be sure to post back what gets you going again.
Good luck!
