Blaze water damage
ANSWERED
So, I have not had any problems with this til yesterday and today with water damage being done with the heart rate which now is a solid green as a result. I have been giving a 25 percent discount and took it upon myself to order the Ionic as far as I am concerned, I have been the unlucky one to get this wet and had water damage done. So, please be careful if any of you have ran into the issue, I have now which is a solid green light on the entire time draining battery very bright and the battery no longer holding its charge... I will be reverting back to one of my older models til I receive the iconic.
Moderator edit: subject and format
1 BEST ANSWER
Accepted Solutions
Hey @liciousgirl2016, it's great to see you around.
I am glad to hear that you contacted support regarding this and were offered a discount which you used. At the moment of receiving your Ionic, you can follow the instructions provide in the help article How do I set up my Fitbit device? to set it up.
If there is anything else we can do for you, do not hesitate to post it. Smiley Wink
4 REPLIES 4
thank you, i anticipate i will enjoy this more then the blaze
Mine got wet while I was out running and it started raining. I’m so disappointed in this product! I feel like I threw my money away.
sorry to hear i went swimming with out it on and it got condensation water in mine so i got an ionic coming from the discount they gave me, i hope the ionic will work as well as the blaze did for me
