04-13-2017 09:15
04-13-2017 09:15
I have had my blaze over a year and it worked great, I have it set to all day sync, but for the last 2 months it will not sync, I have to shutdown the blaze, turn off my iPhone, turn it all back on again, in the hope it will sync, sometimes this works, sometimes it doesn't, like today it just won't sync, it is so frustrating and I am getting over it, it should not be that hard
an advice anyone on why the blaze won't automatically sync and what I can do to have it go back to how it was
thanks all
04-14-2017
05:22
07:12
04-14-2017
05:22
07:12
It's great to welcome you @Littlepud and thanks for troubleshooting this inconvenience by yourself. If your tracker is not syncing, I recommend following the instructions provided in the Having trouble syncing? post. After these steps your tracker should work properly.
Let me know how it goes.
04-14-2017 08:17
04-14-2017 08:17
I'm having the exact same problem! And it says "Update Tracker" in the app, but every time I try to do the update, it stops midway through. I'm beyond frustrated. I've deleted and reinstalled the app. I've scoured the forums. I'm not finding any help.
04-14-2017 15:01
04-14-2017 15:01
My Blaze will not automatically sync anymore. I've had the Blaze for about a year now and I've never had this issue with other mobile devices. I got a new iPhone 7 last week and was able to set up everything without a problem. But the next day when I opened the fitbit app and tried to sync it did not work. I was able to sync once I restarted the Blaze and it will "all-day sync" but the next day I had the same problem. I don't want to restart my Blaze everyday to sync it. Anybody else has this problem?
04-14-2017 15:11
04-14-2017 15:11
I feel you Littlepud. I have the same problem. I've had the Blaze for a year and this issue just started last week. I have to restart my Blaze to sync and just like you sometimes it works and sometimes it doesn't. Today I removed the Blaze from the app and reset it from the beginning. The "all-day sync" worked for a while and stopped working. I called Fitbit customer service and they opened a ticket to investigate. It appears lots of other Blaze users are having same issue. Will keep you posted.
04-14-2017 23:08
04-14-2017 23:08
It seems like most Blaze owners are having problems with syncing and with battery/charge ever since the Firmware update a few weeks ago. Is Fitbit doing anything to address this, aside from pointing us to general tips about making sure your Bluetooth is enabled and cleaning the contacts?? I had no problems with my Blaze before the last Firmware update, then suddenly, mine would hold a charge for less than 24 hours. Fitbit replaced my Blaze 'pebble,' but I instantly have had problems syncing the new one. One day it will sync, then the next day, I'll get a message in the app that no tracker is found. Clearly, something is wrong with the Firmware update that rolled out in March.
04-15-2017 16:10
04-15-2017 16:10
I got mine to sync. I deleted the Blaze from my bluetooth connections on my phone. That's it. I ran the update. I reconnected it and it finally synced.
Now if I could figure out why my Aria isn't syncing...
04-15-2017 18:38
04-15-2017 18:38
04-17-2017 04:35
04-17-2017 04:35
A warm welcome to the Community @jmauden, @Deehlee and @gfp it's great to see you around.
I am glad to hear that for most of you this inconvenience has been resolved. If you keep having problems syncing, I recommend following the instructions provided in my previous post since after following those steps your trackers should sync without a problem.
About your Aria @jmauden, I recommend considering these steps:
Catch you later.
04-17-2017 07:06
04-17-2017 07:06
04-17-2017 20:36
04-17-2017 20:36
Same issues with blaze over and over. I've done everything, including the link posted. It works for a time and then starts not syncing again. It's frustrating and a constant issue that doesn't seem to concern the fitbit makers all that much. I've used fitbit for years but the sameissues over and over again are becoming frustrating
04-18-2017 13:37
04-18-2017 13:37
Hi There,
what is so frustrating about this reply is I have tried all these things - numerous times.
it is getting beyond frustrating that I can't sync, today for example I have tried everything know to man and still I am not syncing
I just wish Fitbit would iron out this syncing problem with the blaze once and for all
04-18-2017 15:44
04-18-2017 15:44
Hi,
I have no answer for you because it is happening to me also but it seems to be since the last update that I have noticed it. I have emailed fitbit for the reason as to why this is happening and yes it is really frustrating I agree.
04-18-2017 16:25
04-18-2017 16:25
yup I posted the same thing two hours ago and I had not replies or help -- no sync cannot update -- the update gets half way through and craps out back to my home screen I have tried to troubleshoot by shutting down ect.. no use beyond frustrated!!!
04-18-2017 16:30
04-18-2017 16:30
I am so hearing you this is also what has happened to me. I hope they fix it real soon because it is so frustrating and your right its been since the last update as very thing was fine up until then.
04-18-2017 16:36
04-18-2017 16:36
yeh that was less then helpful... standard stuff I am having sam eissue
and my sync is interrupted by the update notification on the app - but the update will not update - so frustrated
04-18-2017 18:15
04-18-2017 18:15
04-18-2017 18:37
04-18-2017 18:37
04-18-2017 18:44
04-18-2017 18:44
04-18-2017 18:45 - edited 04-18-2017 18:46
Sorry. This was a duplicate post.
