03-06-2019 03:51
03-06-2019 03:51
My blaze will not charge. I’ve checked my power sources, I’m using the same charger it cane with, tried to reset it, but nothing. I’ve never had an issue with my blaze before. When I put in the the charging cradle I’m making sure everything is lined up. It just flashes a red line in the battery in the screen oppose to the battery showing its charging. Please help!
03-06-2019 10:50
03-06-2019 10:50
Welcome to the forums!
Have you cleaned the contacts?
Hope it helps!
Wendy | CA | Moto G6 Android
03-07-2019 04:23
03-07-2019 04:23
208 Blonde, I’m having the same issue.. started last night when i tried to charge nothing.. any luck?
03-07-2019 19:22
03-07-2019 19:22
Hold down the left & bottom right button for 15 seconds & it should light up.
