12-10-2016 15:14
12-10-2016 15:14
12-10-2016 20:44
12-10-2016 20:44
Wont setup, wont swipe right out of box. The factory reset come back to logo with fitbit.com/setup below. Not real happy with this thing right now
12-10-2016 21:10
12-10-2016 21:10
@Jeff1964 you say you have an update bar, does it increase in lean gtg with every try? If so the easiest thing is to keep trying.. Alternatively yolo can use a different device to update through.
@HermBob got to the setup link through the device that you want to use.. Then follow the prompts to download and install the software
Run and follow prompts.
Best Answer12-10-2016 23:01
12-10-2016 23:01
Hey!
Ystrday i bought dis new blaze..
N i tried of setting up lik a dozen times..n tried all d ways u mentioned . . but the updating bar doesn't appear at all...it is stuck at fitbit.com/setup
N i cnt see the charging logo on d display . .is that common before setup??
Best Answer12-12-2016 05:06
12-12-2016 05:06
Welcome to the Forums @Sam26168, @Jeff1964, @HermBob and @Rich_Laue thanks for stopping by.
I would like to know if you keep having problems setting up your trackers? If you do, I recommend restarting your Blaze and try the setup procedure from a computer. Once you set them up from a computer you will be able to sync your trackers with your phones.
I hope this helps, let me know the outcome. ![]()
12-12-2016 05:17
12-12-2016 05:17
12-12-2016 05:20
