04-25-2019 04:02
04-25-2019 04:02
My Blaze won’t keep a charge for more than a few hours. When I put it in the charger, the screen indicates that it’s charging and I can also see when the screen indicates the watch is fully charged. After wearing it for fewer than six hours, it complete dies and shuts off. There’s still just enough battery to let me turn the screen on, but I immediately get the low battery warning on the screen.
05-03-2019 05:27
05-03-2019 05:27
I'm having same issue. I have restarted and am currently charging, will confirm if this makes a difference or not
05-03-2019 11:08
05-03-2019 11:08
05-03-2019 16:53
05-03-2019 16:53
Lizzyfitbit, I've tried doing the reset option (I've done this 4 straight days) and the other energy saver ideas. So far, I've been able to add an hour or two but I still have to charge at least twice a day.
05-03-2019 17:17
05-03-2019 17:17
I’m having exactly the same issue, and just as suddenly as the rest. I opened a case and after 2 days I got an email with these same suggestions, to no avail. Battery is lasting less than 6 hours!
05-03-2019 17:27
05-03-2019 17:27
I just started having this same issue. Any trouble shooting for past issues hasn't corrected the issue. So I'd like the answer to this as well.
05-03-2019 17:41
05-03-2019 17:41
same problem. worked fine for a long time and now giving me battery dead issues incessantly. I tried all the steps mentioned already.
05-04-2019 00:46
05-04-2019 00:46
Replacement or refund is the answer!
The product is of no use if you can’t use its features!
Simples!
05-04-2019 05:49
05-04-2019 05:49
Mine does this exact same thing. Now it won’t turn on at all and I have tried resetting.
05-05-2019 03:17
05-05-2019 03:17
Thank you for your reply - I am still having no luck at all after following all the suggestions the Blaze only lasts for 3 hours tops . Annoyingly the device has to be synced each time so the date and time is correct. I don't really have the time for this. Rather disappointing- bit sad as really the device is useless now
I'm open to more advice but am thinking I need to look at a different device.
Thanks
NaomiWally
05-05-2019 14:36 - edited 05-05-2019 14:49
Hi @teejay1719, @Stollerbrent, @Amazonkit, @memon01 and @Susanls6405, welcome on board. It's nice to see you around @Inaspin, @JeffRozeveld and @NaomiWally.
I'm sorry for the delay in my response and thanks to all of you for checking the suggestions posted through this thread.
@teejay1719, thanks for restarting your device. I'd also suggest to check our help article which has some tips to maximize the battery life.
@Inaspin and @Stollerbrent, I appreciate you for letting me know about your devices behavior after trying our suggestions, as well for working with our Support Team. I've contacted our team about this situation and apparently they're further investigating your cases. You'll receive an email from them shortly with more information.
@JeffRozeveld, @Amazonkit and @memon01, thanks for your efforts in troubleshooting your devices and because they're not working correctly, I've requested a case for each of you so our team can give you a hand. They'll contact you back via email with more details, so keep an eye to your inbox.
@Susanls6405, I appreciate you for trying the restart and if you've not done so, I'd suggest to try the following steps:
1. Clean the gold contacts on the back of your device and charging cable with a toothbrush and rubbing alcohol.
2. Charge it by using other USB ports or UL-certified USB adapters into the wall.
@NaomiWally, thanks for sharing your thoughts. I totally understand how you're feeling and I'm here to help you with this. I've been informed that our Support team is handling your case and I'd suggest to continue working with them so they can provide you with further assistance.
I'll be around, so keep me posted.
05-05-2019 14:39
05-05-2019 14:39
05-05-2019 14:46
05-05-2019 14:46
Just been offered a replacement (that I’ll probably have to pay customs and Royal Mail charge to receive) or a 50%discount of any new Fitbit
05-05-2019 14:59
05-05-2019 14:59
@Inaspin How long have you had yours for?
Mine's coming up to three years and and I was offered 25% discount or nothing. But I can buy a new one cheaper than the discount if I don't buy directly from fitbit.
So frustrating. I have to charge daily now. Why make a product that can't be repaired?
05-05-2019 15:30
05-05-2019 15:30
05-05-2019 18:43
05-05-2019 18:43
im having the same problem.. my blaze would'nt charge so i did the whole reset thing with the buttons. This actually worked for about a week. Now, not only will my blaze not charge, but it gets hot while on the charger. Ugh!! Frustrating. Fitbit please help, thank you.
05-06-2019 10:51 - edited 05-06-2019 10:54
Hi @teejay1719, @Inaspin, @HannahElRe and @TMex. It's nice to hear from you. Welcome on board @Capaz88.
@teejay1719, thanks for checking our help article and I'm glad you were able to get in touch with our Support Team. They're currently working on your case and I'm sure they'll help you with this.
@Inaspin, I'm glad to hear about the options you received for your Blaze. If you have any questions about that process, I'd recommend to reply back to our Support Team so they can continue helping you.
@HannahElRe and @TMex, thanks for taking the time to share with me your thoughts about your experience with our Fitbit products. We continue to grow and improve as we aim to provide the best fitness trackers, and your comments will not be taken for granted.
@Capaz88, thanks for the detailed information about your Blaze behavior. I understand how you're feeling and I've contacted our Support Team so they can create a case for you. You'll receive an email from them shortly with more details.
See you around.
05-06-2019 20:26
05-06-2019 20:26
I am having the same problem. Needs to be charged every day. Can I change the battery?
05-07-2019 06:48
05-07-2019 06:48
@LizzyFitbit Is anyone at Fitbit wondering why all these battery issues are happening on the Blaze? They dominate the board with relation to the Blaze.
05-07-2019 07:00
05-07-2019 07:00
My blaze is doing the same thing.
Charge it and it last for 4 hours if that.
Ive tried a different charger,
resetting it and on the computer to charge and nothing is working.
Please advise me further?!
05-07-2019 09:57
05-07-2019 09:57
Good news on my Blaze fit bit! In this case the 5th and 6th time of restarting my device and then charging finally achieved the desire results. My device is finally keeping a charge for more than 4 hours. I'm not sure why but yesterday for the first time in almost 2 weeks it stayed charged for more than 4 hours.
Hopefully it will last a while longer.
Thanks!
