02-25-2016 19:32
02-25-2016 19:32
10-04-2016 03:50
10-04-2016 03:50
Thank you so much. I have not been receiving texts messages on my Blaze for over a month now. I new it was a setting I had changed, I just was not sure because I had made so many changes trying to help my phone with storage.
10-04-2016 06:54
10-04-2016 06:54
12-18-2016 16:26
12-18-2016 16:26
Thank you so much!! I was going crazy trying to figure this out!! As soon as I turned that on... now it works!! Thanks again!
12-21-2016 18:12
12-21-2016 18:12
My Fitbit blaze will not send me notifications at all! Once in a while it does. The blue tooth is on and it is connected. I've tried everything I possibly can and have even reset it. I've only had it since mid June. Are there warranties on these and also, what more can be done? I'm very upset and sad that it doesn't notify me.
12-21-2016 19:39
12-21-2016 19:39
@Ktotman83 you mention ios, have you updated your tracker a firmware since yesterday?
I'm not sure what everything is.
Is there any other device that you connected your Blaze to, still aroind? If so turn it or its BT off.
-turned off/on your iOS BT
-make sure the Blaze shows up in the Phones BT as being connected.
-restart phone
-restart tracker
-made sure the notification services are running
-have the phones notification panel set to allow fitbit(?)
-added your Blaze as a replacement device?
There are a few more things to try but I think one of the a love will work.
11-15-2017 18:05
11-15-2017 18:05
Hi
This fix is not helping or "fixing" my problem. I am not getting notifications. Any assistance would be greatly appreciated.
Pati
12-25-2017 10:06
12-25-2017 10:06
FINALLY, after months of trying to get my texts, it was just this easy. THANK YOU.
