10-22-2016 00:26
10-22-2016 00:26
Best Answer10-22-2016 00:59
10-22-2016 00:59
Hi, @Milky6161, try a restart (that's not the same as turning it off and on -- a restart will shut down all background activities and reboot the device without losing any data). You are usually advised to try the restart procedure 3 times if the first restart does not seem to fix your problem.
Hopefully that will get you going again. If not, I would advise getting in touch with Fitbit Customer Support (contact.fitbit.com). Be sure to tell them the troubleshooting steps you have already tried.
Good luck, and let us know how it goes. Welcome to the forums!
Best Answer10-22-2016 01:16
10-22-2016 01:16
