12-30-2019
16:44
13:48
12-30-2019
16:44
13:48
My Blaze will not sync with my Android for the past 4 days.
The usual things to try when you get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
A couple more things to try.
For me one of my last points usually get me up and syncing.
