12-02-2019
19:35
10:58
LizzyFitbit
12-02-2019
19:35
10:58
LizzyFitbit
My blaze would sync fine for almost 2 years now I have to remember to sync manually or it won't happen??? This has been going on for almost 2 months can't seem to get help? Just got my weekly progress report and realized I forgot to sync yesterday... Stinks!!! Not sure I will get another Fitbit if 2 years is all you get and no help is what they offer....
12-03-2019
13:56
13:44
12-03-2019
13:56
13:44
Hi @jewlsiyq. It's good to see you here in the Forums.
I've moved your post to the Blaze board so you can receive more related responses about this situation, and to keep our forums organized.
Thanks for letting me know about your Blaze and I'm sorry that you've had issues to sync it. I understand how you're feeling as it should be able to update your information correctly, let me help you out. Before anything else, have you verified if the "All-day sync" and "Always connected" are enabled in the Fitbit app? Also, have you allowed the Fitbit app to run on the background?
If those conditions are met, please give a try to the following:
You may leave the Fitbit app open on the background and the Bluetooth enabled so your Blaze can sync automatically. If the issue persists, I'll need you to provide me with your phone's model and Android version so I can look into this.
12-04-2019 05:45
12-04-2019 05:45
Agreed, exact same issue
12-04-2019 18:45
12-04-2019 18:45
My Blaze hasn't synced since November 30th. I have tried everything as recommended on the forums. I can get the "Blaze (Classic)" to connect to my Bluetooth, but I cannot sync anything. Every time I try, I get an error message "No Device Found." I also can no longer manually record the data from my Blaze to my app.
Help! Am I going to have to buy a new watch? I've had this one for three years; please tell me that buying a new one is the only option. If so, I'll be looking for a different device. I've had two Fitbits, but am not married to the company.
12-04-2019 18:57
12-04-2019 18:57
After an entire day of working on this problem, I was able to finally solve the problem. I simply turned off the Bluetooth connection on my phone and then turned it back on. All other steps did nothing; only this one. Try it and see if that helps you.
12-04-2019 19:26
12-04-2019 19:26
Same situation here. It worked great until yesterday. It will not sync!
12-09-2019
09:12
13:44
12-09-2019
09:12
13:44
Hi @HAPPY2BAHICK, @ltrites and @KWilson56. Welcome to the Community. I'm sorry for my delayed response.
@ltrites, that's great news. Thanks for your efforts while troubleshooting this situation and I'm glad that your Blaze is now syncing correctly. I understand how you're feeling about this and be sure that our team will work on our devices and the app to improve their performance. Your feedback is appreciated.
@HAPPY2BAHICK and @KWilson56, thanks for letting me know that you're having the same experience with your Blaze and just to confirm, have you tried the steps posted above? If the issue persists, please give a try to the great suggestion posted above and monitor your tracker's behavior.
