07-11-2016 17:35
07-11-2016 17:35
Best Answer07-11-2016 18:27
07-11-2016 18:27
Best Answer07-11-2016 18:34
07-11-2016 18:34
06:37
16:41
09-18-2016
06:37
16:41
It's great to see you around @jlpizmee and @Aly1028 welcome to the Community. Thanks for sharing the tips you tried to fixed the syncing inconvenience you were experiencing.
I would like to know if you keep having syncing inconveniences? If you do, I recommend following our syncing troubleshoot. After these steps the tracker should sync without a problem.
Let me know how it goes. ![]()
Best Answer10-20-2016 08:39
10-20-2016 08:39
I notified customer service directly that I was having this issue via Twitter AND spoke with them over the phone about two weeks ago to no avail. Their solution was to purchase another Fitbit and they would give me a discount. BOTH OF MY FITBITS PAIR TO MY CELLPHONE (One & Blaze) so there is no issue with connectivity. As I explained to customer service, this did not start happening with my phone until the latest Note 4 os update. It's not the devices. There is an issue with Fitbit and the new Android operating system and it would be nice if Fitbit would look into this instead of suggesting people purchase new devices.
Best Answer10-27-2016 05:42
10-27-2016 05:42
You are not Alone. I had a Note 3 that worked fine until my company upgraded me. I crash most days. I've tried resetting the Fitbit, uninstalling and reinstalling the app and usually one of these will work. The only reliable way I've got at the moment is to use the USB charger into my laptop using the Fitbit app I downloaded from the store.
Best Answer11-02-2016 11:35
11-02-2016 11:35
Best Answer08-20-2017 20:22
08-20-2017 20:22
Still unable to sync but I get notifications.
Best Answer08-20-2017 20:26
08-20-2017 20:26
Tried these steps and it still doesn't sync.
