06-20-2017
10:33
05:16
AlejandraFitbit
06-20-2017
10:33
05:16
AlejandraFitbit
I tried to turn it on, but it has a bar charging. When it gets to the end, the bar comes back to the middle and starts again charging. The Fitbit finally never turns on, and so I can't use it, neither make the setup.
Please help, thank you!
Moderator edit: Caps
06-21-2017 05:17
06-21-2017 05:17
It's great to welcome you @max17. If you are having issues turning on your Blaze, I recommend fully charging it and then try the restart procedure.
I hope this helps, let me know the outcome.
06-21-2017 14:35
06-21-2017 14:35
06-21-2017 16:17
06-21-2017 16:17
I am having the same issue. I have tried to set up the blaze 7 times and each time after I put in the 4 digit code, I get an error message.
06-22-2017
04:32
10:35
06-22-2017
04:32
10:35
Thanks for the information @max17 and @melfnp welcome to the Forums.
Could you please tell me which error are you seeing @melfnp? In the meantime, please confirm you are doing the following from your Fitbit app to paired your trackers:
See you around.
06-22-2017 04:42
06-22-2017 04:42
06-22-2017 11:38
06-22-2017 11:38
06-23-2017
04:12
10:20
06-23-2017
04:12
10:20
