08-14-2017 16:59
08-14-2017 16:59
I was charging my blaze and when I went to check it it would t turn on. I have restarted it but nothing. I know my charger is working because I tried it with another blaze. What do I do?
Best Answer08-15-2017 13:24
08-15-2017 13:24
Hi there @Kbach16. Good to see you in the Community Forums! 🙂
I'm sorry you're having problems with your tracker not turning on 😕
Whenever you put it in the tracker, does anything come up at all? I would say, try to restart it about two or three times more and see if this makes any difference.
Also, even if it doesn't turn on, do you see it syncing? For this, check your app and see when was the last time that your tracker was able to sync.
Let me know how it goes!
