05-28-2017 22:57
05-28-2017 22:57
Hi guys! Can you help me???Blaze not notifying nothing with my Galaxy s8 plus, and the sincyng is so slow...
Best Answer05-29-2017 00:03
05-29-2017 00:03
It may not be possible to fix this. According to this thread - https://community.fitbit.com/t5/Alta/Samsung-Galaxy-S8-Plus-and-Alta/m-p/1960775 - the S8 Plus is not fully supported by fitbit.
05-29-2017 00:03
05-29-2017 00:03
05-29-2017 04:54
05-29-2017 04:54
It's great to see you around @stefapet and @SteveH thanks for stopping by.
I would like to know if the instructions provided by our friend @SteveH worked? As mentioned, Samsung Galaxy S8+ is not a compatible phone. Keep in mind that your phone needs to be 100% compatible in order to work properly with your Blaze. However, you can try the instructions provided by @MarreFitbit in the My tracker isn't receiving notifications (Android Fitbit app) post.
Catch you later. ![]()
06-07-2017 05:53
06-07-2017 05:53
Okay, so I've done a little research, and it seems the issue probably lies with Samsung. The GS8 has Bluetooth 5, which does not seem to be completely backward compatible. In addition, there are ZERO Bluetooth 5 devices available on the market, and they do not expect any to be available until maybe early 2018. That means that Samsung does not have any Bluetooth 5 devices on the market either. So, here we are with this really cool phone, that cannot be used to it's full potential. It will be really cool... someday!
06-07-2017 07:31
06-07-2017 07:31
This definitely makes me sad, while I have been excited about the Samsung S8 (I am not on the plus but have the same issues) it really is hard to get this to Sync, etc.
I know my notifications are delayed at times. If only I wanted all those notifications for my work phone I might consider using it on my work phone, but, I digress.
It is a shame that this does not work, however I really did not do research on the phone and my Fitbit, sort of figuring Bluetooth, was bluetooth, but things are not always as they seem. 😞
06-26-2017 15:29
06-26-2017 15:29
My S8+ from AT&T did a software update late last week, and I started getting notifications. Scared the heck out of me the first time it buzzed while I was driving! ![]()
It also doesn't seem to be draining the battery as badly as it did before, although I also don't have it connected via Bluetooth, as the music control doesn't matter as much to me, or at least I haven't been in a position (a long walk) where I would need it since the update. I'm guessing the battery drain will come with that connection.
07-15-2017 10:30
07-15-2017 10:30
Samsung S8 is a new phone - and has an increasing community of users.
clearly the blaze i bought cannot send notifications to this and is pretty weak connecting to android in general.
so this issue of notifications needs to be fixed
what is the roadmap to get this working
or should we just look at other devices since conclusion is that fitbit has no roadmap
Best Answer07-15-2017 11:44
07-15-2017 11:44
If you are expecting Fitbit to reply, you've come to the wrong place. Since this thread is marked as being "solved" they no longer pay any attention.
Is there a newer post out there that is not incorrectly labeled as solved? If not, one needs to be started now that the S8 is in fact on the compatible list.
Best Answer08-15-2017 13:38
08-15-2017 13:38
Its not a solution then is it 🙂 Im hoping there is a resolve for this further down
Best Answer08-15-2017 13:40
08-15-2017 13:40
Well this is poor on fitbits part!! I think I will sell it and get a watch that does work
