Blaze won't turn on
Today my Blaze went dead. In the middle of my cardio my screen turned super bright and froze up. I stopped working out to see what was going on, and it just stayed stuck. Then the screen suddenly started flickering, and no longer showing a clear display.
I tried to reset it, and it showed "clock face error". I changed the clock, and began working out again. It did the same thing 20 minutes later, so I tried to reset it again. Now, it doesn't even turn on. The green light is not on either. It's dead. I placed it on the charger to see if it would come back to life, nope. This was their idea of a replacement unit that died in the 8th month of use. I have only had this for just under 5 months. Planned Obsolescence.
2 REPLIES 2
It's great to see you here @Niecy17.
Thanks for troubleshooting this by yourself. Since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Let me know the outcome. Smiley Wink
*Thank you for doing that.😊*
