Blue tooth connection for music
ANSWERED
using a Galaxy J7.  If I have the phone using a blue tooth speaker, my watch will not connect and control the music playing.  it looks like it tries and just flashes off and on.  Can the phone be only hooked up to 1 device at a time???
1 BEST ANSWER
Accepted Solutions
Hello @popples, when you turn of the external speaker, are you then able to control the volume and music? If not restart the phone.
When it comes to using the two at the same time, does your speaker also have music control? Go into the phones Bluetooth setting, i was able to tell Bluetooth to ignore the input control of the speaker, and then it did use the Blaze as an input to control music.
1 REPLY 1
