12-28-2017 18:03
12-28-2017 18:03
Hello everyone I am trying to figure out why my fitbit blaze keeps discounting from my galaxy s8. It will sometimes stay connected for about 5 hours max. And then I have to try to reconnect it.
Best Answer12-28-2017 19:34
12-28-2017 19:34
Have you enabled always connected?
I find my blaze and ionic stay connected. However the ionic is a pain to get to sync
01-05-2018 06:31
01-05-2018 06:31
Yes I do have it on always connected and for some odd reason I sometimes do not get text or calls on my blaze
Best Answer01-05-2018 06:55
01-05-2018 06:55
@Superman1997 wrote:Hello everyone I am trying to figure out why my fitbit blaze keeps discounting from my galaxy s8. It will sometimes stay connected for about 5 hours max. And then I have to try to reconnect it.
I am having the same issue with my s8, for some reason all of a sudden my phone abd blaze wont connect, have you managed to find a solution to this?
Best Answer01-05-2018 09:24
01-05-2018 09:26
01-05-2018 09:26
Gutted! If i find a solution I'll post it, cheers
Best Answer01-05-2018 11:19
01-05-2018 11:19
Ok thank you.
Best Answer01-05-2018 17:06
01-05-2018 17:06
Restarting the phone usually works for me.
Lately I have found the phones permissions have been switching off.
