10-04-2017 16:59
10-04-2017 16:59
I have nothing displayed on my blaze but it is still tracking my steps and heartbeat. I want to try to reset it, but the buttons don't work. Is there another way to reset through app?
11-14-2018 04:01
11-14-2018 04:01
Best Answer04-30-2019 15:54
04-30-2019 15:54
I tried this and it does not resolve my problem. Is there another work around? Please advise.
Best Answer04-30-2019 18:16
04-30-2019 18:16
My buttons all just stopped working too. The unit is clean. Reseting did not work. Can someone from support contact me with a fix? Thank you.
Best Answer05-01-2019 11:11
05-01-2019 11:11
Could there have been a software update that disabled this functionality?
Best Answer06-03-2019 17:27
06-03-2019 17:27
I have the same problem
Best Answer07-08-2019 16:12
07-08-2019 16:12
I am currently experiencing the same issues with the left button on the Blaze. I have followed all troubleshooting, but nothing is working. What are the next steps in solving the issue? Thanks in advance for the assistance.
Best Answer07-08-2019 16:21
07-08-2019 16:21
Unfortunately, I have not gotten ANY response from Fitbit. I did, however, discover that by alternating between *holding down* the left and right bottom buttons (together ~ 15 secs) and the left and right top buttons (together ~ 15 secs), that it'll revert back to the menu selection. From there, you can swipe left or right to get where you need to be.
Frustrating, I know...
07-08-2019 16:24
07-08-2019 16:24
Best Answer07-29-2019 10:38
07-29-2019 10:38
I contacted support and their solution was to buy a new one I've spent more than $600 on Fitbit devices. I'm not about to spend another $150 after this one breaks in less than a year.
Best Answer07-29-2019 10:39
07-29-2019 10:39
I reset the clock face and it didn't work for me 😣
Best Answer07-29-2019 10:40
07-29-2019 10:40
I contacted support and their solution was to buy a new one. I'm not about to spend another $200 after this one broke in less than a year.
06-11-2020 02:02
06-11-2020 02:02
Left side single button when pressed does alter the blaze watch and bring up the clock display.. All other functions work, clock display can be changed from the App and displays but then goes off for power saving, I cannot recall the screen. Button is clear of dirt. All other functions operate.
09-16-2020 10:17
09-16-2020 10:17
Thank you! Only thing that worked for me in this thread... My buttons still don't work, but at least I'm not stuck in a submenu anymore...
Best Answer09-20-2020 23:38
09-20-2020 23:38
Hi Alejandra,
Having exact the same problem as Emma. Can you please help me out.
Thanks!
Saskia
