10-17-2016 08:57
10-17-2016 08:57
This one always bothered me with the Blaze and I was hoping in the subsequent updates this would be fixed. I can set a timer for a stopwatch function but I cannot do the same when setting or changing an alarm. I would even be content to just changing and if I needed to set up a new alarm go to the app. Why would it be difficult to allow numbers to be updated in the alarm feature and then when you sync the watch always superceded the app and updates the app as well. It seems like stopwatch already allows you to set a time just use the same coding towards the alarm function.
09:37
07:55
10-18-2016
09:37
07:55
Hi there @almirx. Good to see you around! 🙂
I was not able to find a concrete request for this since this feature is not currently available so I can suggest creating a new feature suggestion in the Feature Suggestions board for others to be able to vote for it (I personally think this would be awesome) and hopefully to be reviewed by our team to consider implementing it.
Anything else I can help you with, let me know!
Best Answer10-18-2016 11:20
10-18-2016 11:20
Thanks for the reply Ferdinand. I will post it hopefully the programmers and other users find it helpful to be able to do this. I know travelers and people that might not have internet connection will love to be able to change the alarm without having to use the app (which requires internet to be able to do anything even change alarms).
10-19-2016 04:54
10-19-2016 04:54
09:08
07:55
10-19-2016
09:08
07:55
Hi @Gemma62. Welcome to the Fitbit Community! 😄
In the Fitbit Community we do our best to provide a global experience,
Best Answer10-19-2016 12:39
10-19-2016 12:39
grazie
