Changing From Charge to Blaze
ANSWERED
I just upgraded to the Blaze from the Charge and was wondering if anyone knows how to move my history from the charge to the Blaze?
1 BEST ANSWER
Accepted Solutions
Hello and welcome to the forums @Becky36
When you set up your new Blaze, be sure to first sync the Charge one last time. Set up your Blaze as a replacement for the Charge, using the same account and all the history will be there. These devices pair to the email address and the history is kept on the servers on that account.
Keep on stepping!
Stepping in the U.S.A. since September 2013. Android 14
4 REPLIES 4
Keep on stepping!
Hi Becky36,
and, besides what Odyssey13 has suggested, it wouldn't be a bad idea to remove your old Charge from your account after it's last synchronisation if you're not planning to use it in rotation with your Blaze.
Regards,
Stefan
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
@Becky36 of you set ouit up on the same account the Charge was on then you would still see the history. Nothing is ever stopped on the tracker, bit is kept with your fitbit account.
@Becky36 welcome to the Fitbit Community! 🙂  @Rich_Laue@Talahthas and @Odyssey13 thanks for your cooperation! @Becky36 where you able to set up your Blaze?
Retired ModeratorAngela | Community Moderator
It is health that is real wealth and not pieces of silver and gold! Share your story!
