09-24-2016
10:00
20:26
DavideFitbit
09-24-2016
10:00
20:26
DavideFitbit
I have the Samsung edge 7 is my phone compatible with the Blaze
Moderator edit: subject update for clarity
08:25
08:30
09-26-2016
08:25
08:30
Hi there @Csaavedra. Good to see you around! 🙂
Sometimes newer phone models are not added right away to the list of compatible devices because they need to be tested and it can take a while but most new models are able to work with Fitbit trackers so as @werionae said, even if it is not there, it seems it will work just fine 🙂
Anything else you may need, let us know!
