04-27-2017 07:18
04-27-2017 07:18
My blaze fitbit I believe is connecting to my co worker blaze
im recieving her messages
04-27-2017 09:38
04-27-2017 09:38
I would like to suggest trying to restart your tracker as explained in this article. And if that does not fix it, try to pair it again with your phone via the app. I hope it works.
Karolien | The Netherlands
04-27-2017 07:39
04-27-2017 07:39
It's not possible for Blazes to connect to each other and transfer messages. Similarly, messages will only be sent from the phone that the Blaze is paired with so accidental transmission isn't a realistic possibility.
Is it possible you've swapped Blazes in error?
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
04-27-2017 08:32
04-27-2017 08:32
No. My balze is on my arm until i lay down, nothing is 100% its possibe its happening
04-27-2017 09:05
04-27-2017 09:05
We both have fitbit Blaze and I am seeing her messages frim time to time
04-27-2017 09:38
04-27-2017 09:38
