10-20-2017 05:23
10-20-2017 05:23
Have to go through the rigmarole of resetting bluetooth, app and shutting off Blaze daily , this has been going on since the last software update. Not happy.
10-28-2017 08:11 - edited 10-28-2017 08:13
So I was having the same problem where it took an act of god to make my fitbit sync (and I no longer got notifications on my fitbit). I believe the problem is Bluetooth (Classic), which is really only used for music control. This solution worked for me
Step 1 - Use the fitbit app to disconnect your blaze from your account
Step 2 - manually go into your phone's bluetooth and "forget device" for blaze and blaze classic
Step 3 - On your blaze, turn off bluetooth classic via the settings menu
Step 4 - Using the fitbit app, reconnect (add device), and follow the steps to reconnect your blaze to your account
You will need to re-do all your other settings, notifications and alarms (through the app).
But now I'm getting notifications again and I've had zero trouble syncing my device since I reconnected. GPS even works again. I've even been away from my phone, and had my phone connected to other bluetooth devices, and when I re-open the app, fitbit connects right away, just like it used to.
The only downside so far is that you won't have music control anymore (that's the only thing that really uses bluetooth classic), which isn't a big deal for me. If I have bluetooth headphones on, I skip, pause, & hit play through other means anyway,
TL/DR - turn off bluetooth classic
10-21-2017 05:26
10-21-2017 05:26
Hi
10-22-2017 06:00
10-22-2017 06:00
Hey @SunsetRunner, welcome to the Forums, thanks for troubleshooting this by yourself and @SunsetRunner for stopping by.
I would like to know if you have followed our friend's recommendations and get in touch with our support team? If you haven't and before you do, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there.
I hope this helps, let me know the outcome. ![]()
10-28-2017 02:33
10-28-2017 02:33
Still the same problem as detailed above, it is most definately a software mistake on your part. No problem before the last update, all these problems after the update.
10-28-2017 04:12 - edited 10-28-2017 04:15
Have you been able to contact the support team?
Which phone do you use to sync? (iOS, Android, Windows)?
Does the tracker having issues to sync on the phone only or also when sync'ing on the computer?
Does the tracker having problems sync'ing on a wifi connection or mobile internet connection (or both)? (costs can apply when not having a mobile internet plan).
Feel free turning off the internet router and turn on again if not already done.
Fitbit Article: How do Fitbit devices sync their data?
10-28-2017 05:41
10-28-2017 05:41
Thanks for jumping in @SunsetRunner! Hi @SunsetRunner, thanks for getting back! ![]()
I'd like to know which model of phone you're using to sync? Also, if you got those issues after the last update, please follow these steps to reconnect you Fitbit with your account since it has been helpful for some users.
Please keep me posted!
10-28-2017 08:52 - edited 10-28-2017 08:54
That seems to work.... Very many thanks!
10-31-2017 09:08 - edited 10-31-2017 09:10
Hi @Azsunyx, thanks a million for the amazing information you've shared! This helped our friend @SunsetRunner, it's good to know what is working for you guys. Keep updating your comments and workarounds, we really appreciate your thoughts! ![]()
In case that you have questions about your Fitbit or you can just hand around, I invite you to stay in the Forums; there is plenty information here and new ways to make friends. Please take a moment to visit our Discussions board where you will find other members sharing their experiences and tips.
This is a really good way to stay motivated towards your goals. In case that you haven't do so, check it out! You might be interested in these topics: You know you're a Fitbit addict when...... or Looking for Fitbit Friends? Find some here!
Happy stepping! ![]()
10-31-2017 10:15
10-31-2017 10:15
Have Fun ![]()
Enjoy all Nourishment ![]()
03-12-2019 07:56 - edited 03-12-2019 08:09
I have done all these steps a million times on my Versa and still it goes out of sync every morning.
It says "Tracker not found" or "Restart Bluetooth". I have a Samsung Galaxy S8 phone and Fitbit Versa.
