@jared.ruby When the timer stops, it will vibrate to notify you. There is not an option for sound as the Blaze does not have any speakers or capacity to make audible sounds.
Hope that helps you~
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
05:55
09:57
04-24-2017
05:55
09:57
A warm welcome to the Community @jared.ruby and @Kmransom123 thanks for stopping by.
As our friend @Kmransom123 mentioned, the tracker will vibrate once the time you set is over. I took the liberty and searched for a request like this but didn't find any, please visit our feature suggestion board and share your suggestions.
Catch you later. ![]()
