I have had my Blaze for just over a year now. I cannot get it to charge.
when I hold it in the charge cradle it works perfectly, but as soon as I lift it up off the charge pins it is dead.
So I know it is getting a charge into the unit but not charging the battery.
Do I need to exchange battery, is this possible.
Regards
Jim
If that did not solve your problem, I would highly suggest contacting Fitbit Support via Chat! I have contacted Fit it Support over some big problems with my Fitbits in the past, all the at from ripped bands to bad screens. They always came through!
Michael Groff | CO, USA
Fitness isn’t being better than someone else, it’s being better than you used to be!
Hi @JVS23!
Have you tried cleaning the battery connectors on your Blaze?
Let me know if that helps.
As for replacing your Blaze’s battery, I won’t say it’s impossible, but it’s not really made to be replaced.
Also, try a restart. Below you will find the short steps you have to take in order to restart your tracker:
1.) Press and hold the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.) Let go of the buttons.
Best AnswerThanks for the information RK.
Sadly it did not rectify the problem.
I noticed it still syncs when in the charging cradle.
Just will not take a charge.
Maybe I just need a real long charging cable so I can take it for a run....lol
Thanks again for your help.
Jim
