06-24-2016
07:46
11:50
AngelaMa
06-24-2016
07:46
11:50
AngelaMa
My friend and I both have the blaze. I have an android and she has an iphone. We walk/run side by side, same time, same distance. Why are our blazes not reading the same. Mine is consistently reading less mileage, longer run times and longer pace times.
Moderator edit: format
06-29-2016 01:33
06-29-2016 01:33
06-25-2016 00:55 - edited 06-25-2016 03:02
Im not sure if i understand, have both of you setup your stride? When walking do you use the connected gps on the phone, or let the walk autodetect?
Which readings are yoy reverting to, it is unlikely that your step count and calories will match.
06:55
11:50
AngelaMa
06-25-2016
06:55
11:50
AngelaMa
we are both using our phone gps. the gps automatically sets up our stride.
Blessings,
Laura Matlock
Moderator edit: removed personal information
Best Answer06-25-2016 08:52
06-25-2016 08:52
I know that when tracking the run on the Blaze with the connected GPS your stride will be determined by the distance the GPS said that you ran, and the steps the Blaze said you took
Im not sure if this is so when using the run tracking of the Fitbit app, but either way when using the GPS durring running the distance is measured by GPS, not the stride.
I'm still not sure what measurements are different, the OP looks like it was cut off.
09:58
11:51
AngelaMa
06-25-2016
09:58
11:51
AngelaMa
What is OP?
This morning our first 3 miles showed 3 miles on her iphone. On mine it
showed 2.77....
The farther the distance we travel the larger the descrepency
Blessings,
Laura Matlock
Best Answer06-25-2016 13:49 - edited 06-25-2016 13:50
OP is original post.
Did you start the exercise would the phone or the Blaze? You said walk/run so I assume it was tracked as a walk, i ask this because we see evidance that suggests that tracking a walk with the Blaze doesnt use GPS to record miles.
06-25-2016
16:02
04:50
AngelaMa
06-25-2016
16:02
04:50
AngelaMa
My friend has an iphone, I have an android. We use our gps from our
phones. We track through the "run" exercise as we are training for a
marathon. The strides are automatic with the gps. So the question/issue
is why is my friend consistently recording longer distances, short pace
times and longer mileage than I am. We start and stop at the same time and
the same place.
Blessings,
Laura Matlock
Moderator edit: removed personal information.
06-28-2016 04:57
06-28-2016 04:57
Hello @HelenParr welcome to the Fitbit Community! 🙂 I haven't heard of any report similar to what you are experiencing. I would like to ask more questions to better understand your issue. Are both apps up to date? Also have you noticed if the app stops during your run? Next time you are running please keep an eye on the app to make sure it didn't pause or stop during the activity. I would also appreciate if you can post a screenshot of your app and your friend's app showing the discrepancy so I can further investigate. @Rich_Laue thanks for your amazing cooperation! 🙂
I'll be around if you have any questions! ![]()
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer06-28-2016 05:04
06-28-2016 05:04
My blaze does the same thing, its doesnt record distances accurately, i go on the same 2 mile walk every day, and fitbit records the distamce anything between 1.5-2miles, i laos use Strava for the same walk and it records it accurately at 2 miles.
I used to have a HR Surge, and never had any problems.
06-28-2016
08:27
12:21
AngelaMa
06-28-2016
08:27
12:21
AngelaMa
Thank you so much.
Blessings,
Laura Matlock
Best Answer06-28-2016 08:42
06-28-2016 08:42
I've done some testing. Mapmyrun, Mapmywalk, Mapmyride, Map myfitness, Charity Mikes, Strava, the Blaze, the Surge, the car, Google Maps, and the Fitbit app, rarely agree, there close but not spot on.. Which is interesting considering the first four mentioned are the same program by the same author, Under Armor, just different names, and they still don't agree.
10:30
12:21
AngelaMa
06-28-2016
10:30
12:21
AngelaMa
I think we'll just have to be satisfied with the readings we get.....I
suppose nothing will be totally accurate.
Thank you so much for taking time to help me with this.
Blessings,
Laura Matlock
Best Answer06-28-2016 10:43
06-28-2016 10:43
With the Blaze there are two ways to get the distance.
GPS and step count multiples by the stride.
In theory gps should be more accurate.
Step count and stride depend on many things.
Accuracy of the the steps counted, easy to confirm with a step count test.
Stride using several tests to determine the average stride can give close distance
Your stride will vary based on the terain, hills, how you feel, even what is going through your head at the time may affect the speed your moving at.
11:35
12:21
AngelaMa
06-28-2016
11:35
12:21
AngelaMa
0551 is June 20, my friends iphone
13311 is June 23, my friends iphone
The screenshots are ffrom my android
Blessings,
Laura Matlock
Best Answer06-29-2016 01:33
06-29-2016 01:33
06-29-2016 05:51
06-29-2016 05:51
My android is off by .5 then grows as the distance gets longer.....but it makes sense.
Thank you.
Best Answer07-13-2016 08:47
07-13-2016 08:47
I am having the same issue. I have compared it to downloaded apps on my phone and the aps register between .20 and .25 more than my Blaze. My husband also has the Blaze and we walk the same distance and his registers .25 higher per mile we walk. Having two different phones should not make a difference. A mile walked is a mile walked. Even if there were a slight difference, I would understand given all the factors. However, .25 miles? That means my 4 mile walk was a 5 mile walk for him?
07-13-2016
09:26
06:13
AngelaMa
07-13-2016
09:26
06:13
AngelaMa
I'm not real pleased with this new blaze and it's readings.....the distance
has never been close. I've also compared to other phone apps. I realize
there will be slight differences, but this is just to far off
Blessings,
Laura Matlock
07-13-2016 09:37
07-13-2016 09:37
Best Answer07-13-2016 09:59 - edited 07-13-2016 10:25
I wore both watches and mine read 1.01 miles, his read 1.50. Half a mile! I am so frustrated.
I also looked in the FitBit Help section and did not find an answer. Where else is there to go to get help, other than calling directly?
I cannot wrap my head around why there would be such a huge discrepancy between "calculated" and GPS. For the amount I paid for the Blaze, it should be darn close.
