05-12-2016 14:31
05-12-2016 14:31
Okay I have set 3 times now my Profile to Feet and Inches and saved them. Then suddenly a few days later it will revert to Kilometers. Anyone know why this keeps happening?
Thanks,
05-14-2016 05:42 - edited 05-14-2016 05:42
Hello @Andhanni, hope you are having a great day! I haven't heard any report of this so far so I would like to ask some questions: Are you still experiencing this issue? Are you using a computer or mobile device to change your settings? Any additional informaiton will be helpful 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
05-14-2016 20:11
05-14-2016 20:11
Hi @AngelaMa
I use both the computer and the mobile app for different things. I record Water and Food with the mobile app along with Syncing my Blaze. But I use the computer to check the dashboard, and set the defaults on my blaze as I could never figure it out on the Smartphone.
Hope this helps some if not let me know what else you all need. All I can say is it is fustrating at times to see on the Mobile App that I am in KM instead of miles and other items over on the dashboard too.
05-20-2016 06:46
05-20-2016 06:46
Hello @Andhanni hope you are having a great day! Thanks for the information I will keep an eye on any report about this issue and let know if I have any update.
Thanks for stopping by! 🙂
