07-13-2019 00:24
07-13-2019 00:24
Once I have taken my blaze off the green lights are constantly on, it doesn't go into sleep mode, causing the battery to run down far quicker than it should and I then have to put it in a drawer to stop it illuminating the bedroom, how can this be fixed please?
Best Answer07-13-2019 06:45
07-13-2019 06:45
Hi, did you check you heart rate setting? On would leave the lights running at all times. Auto would shut the lights off when not wearing it. If it's working properly.
Best Answer07-13-2019 07:14
07-13-2019 07:14
Best Answer07-13-2019 07:46
07-13-2019 07:46
You're welcome. Glad it was an easy fix for you.
