Hi
Did you contact them from the official contact page?
Feel free to check out the Fitbit Help Article(s):
URL: Click to go to the Fitbit Help Article 'My tracker's battery isn't charging'
Why can't I update my tracker?
http://help.fitbit.com/articles/en_US/Help_article/2047
Hope it helps
Best AnswerWhen the display shows the setup screen, there will be no indication of it charging.. Put it into its charger for 30 - 60 minutes, then try the update again. It will either work or give aow battery warning.. You can also leave it in the charger during setup.. Or if you have a pc you can set it up by plugging the charger into a USB port, place the blaze in it, then set it up through the computer.
Best AnswerThanks. It has sat on the charger well over 4 hours. It is not charging. Probably going to return it.
Best AnswerThanks. I have run through all of these options and my contact was from the official contact number. To no avail. I contniue to get the same screen even after attempting a restart. No charge is taking place. regardless of USB port. I will likely have to return this product. Disappointing...
Best AnswerI am really frustrated with this product. I am in the same situation and I've tried using computer to update but the website tells me to get the app, which effectively puts me in the same circle of waiting for it to charge (to no avail) and getting the error message every time. Setting up the MS Band 2 was absolutely a breeze. As a new customer, I am so disappointed.
Best Answer@RedeemedOne this is a limitation of Bluetooth, a client, your tracker, may only connect to one server at a time. Being connected to the phone will keep the computer from connecting, as you found out breaking the phone connection is the fix.
@AZ91 that's true, the web browser is not able to communicate with a tracker, you may use the Fitbit win 10 app or the Fitbit connect with the computer. Go to the address shown on the tracker, this page will send you to the correct software for the computer you have.
@AmandaLee888888 please give us some information, there are several steps involved in the setup at which step does it fail.
Are you using the Fitbit software on what device? Your not using the devices Bluetooth settings. Http://help.fitbit.com/?q=setup
Best AnswerHow did you get your screen to stop saying, set up. My app is all set up on the computer and phone. I didn't realize so many were having this problem!
Best AnswerMine doesn't say to update but won't get off the set up screen. So frustrating when I've spent so much on this device!
Best AnswerThat seems so weird. I have no idea how I'd get mine working properly. This is so frustrating! Anyone else have any hints or ideas?
Best Answer@Kelly_Wall or anybody else.
Make sure you are using the Fitbit software to setup the tracker?
If it is not working, please don't say it doesn't work without telling us what device and OS your using to set it up. Also please let us know at what step it fails at?
Best AnswerThe fitbit software was downloaded onto my mac last night. I have the Fit Blaze that came in the mail yesterday. My phone is an android that also has the the fitbit app downloaded. This is my 3rd fitbit, with each time being an upgrade. All I can get my fitbit to show is "fitbit.com/set up". When I go to the app via computer or phone it appears everything is all synced. With my other two fit bits the set up/ activation process was so simple. It looks like I'm not the only one that's had this issue. I'd just really like to get this up and running as I'm not super tech savy but trying my best! Any help getting this figured out is appreciated!
Best AnswerI finally solved my problem which was the same as yours..my screen was stuck on set up..I had to add fitbit blaze again on the app and it finally worked properly
