12-29-2016 03:58
12-29-2016 03:58
My heart Rate monitor simply stopped working, I cleaned it and changed it to the other arm, still no results...
03-27-2017 00:13
03-27-2017 00:13
03-27-2017 04:17
03-27-2017 04:17
04-04-2017 18:42
04-04-2017 18:42
Thank you! Did update was wonder what happened!
04-06-2017
05:37
08:53
04-06-2017
05:37
08:53
04-06-2017 22:44 - edited 04-06-2017 22:50
The same thing happened to my Blaze, only one green light is flashing. Heart rate is not being detected. If have tried all of the troubleshooting tops, and nothing has worked. I took it off my wrist, and placed it on the couch while typing. Heart rate is now saying 197, without being on my wrist. Put it back on my wrist, and it worked for a few seconds and then stopped.
04-11-2017
06:18
08:53
04-11-2017
06:18
08:53
Hi there @Madpurse1963. Great to see you in the Community Forums!
I'm very sorry to hear that your heart rate is not working as expected and since you mentioned that you've already tried all troubleshooting steps mentioned before, I would like to forward your case to the Support dept for them to take a deeper look and help you get back on track.
Please keep an eye on your inbox for further instructions and if you need any more help, let me know! 🙂
04-17-2017 13:56
04-17-2017 13:56
Thanks for the advice. Helped me when the tracker stopped at school. (Senior Middle)
04-17-2017 13:59
04-17-2017 13:59
Most likely this but the heart rate may have gotten wet. If you haven't gotten it wet then try calling support. Might just be hardware issues.
04-18-2017
12:31
04:57
04-18-2017
12:31
04:57
04-21-2017 09:34
04-21-2017 09:34
I've had my blaze for a bit more than a year and the JR monitor does not work. The lights flash but it does not capture my HR. I've tried all the suggestions in this post several times, but no luck. Please help...
04-24-2017 12:12
04-24-2017 12:12
Apparently, the motor that controls the heart rate monitor was not working. I have received my replacement Blaze, and I am up and running once again.
Thank you!
04-24-2017 12:51
04-24-2017 12:51
hello, i have also problem with my HR minitor.
It works sometimes,sometimes not. When i sit in front of computer or go to sleep, it just show -- the whole time. When i do sport,it shows something, but may not correct.
Both green light blinking, setting is on on, restart i tried too....still working not well.
I bought it last month,it works pefect for the first three weeks and then......suddenly like this? I dont know what i can do now, pls help me!
04-29-2017 06:50
04-29-2017 06:50
I also have been having problems with the Fit Bit Blaze. The heart rate monitor stopped working on me and the light still blinks and no heart rate on either the phone or the device itself. I have powered it down fully recharged it and still cannot get the HR monitor to work.
04-29-2017 11:46
04-29-2017 11:46
04-29-2017 11:46
04-29-2017 11:46
06-02-2017 14:08
06-02-2017 14:08
I had same problem with blaze heart rate not working. Your fix worked first time! Thank you
06-03-2017 01:44
06-03-2017 01:44
Thanks this also happened to my FitBit Blaze - the green lights stopped working for no reason. Your solution was correct. Much appreciated.
06-06-2017
08:22
04:57
06-06-2017
08:22
04:57
07-08-2017 02:19
07-08-2017 02:19
I tried rebooting the device, it did not work. I am not getting a reading for my heart rate. The green lights are still flashing.
07-19-2017 17:04
07-19-2017 17:04
I have tried all the solutions multiple times, and none have worked for me. The geeen light are both working
