01-23-2017 12:57
01-23-2017 12:57
I wear my FitBit all the time, use workout mode 2 or more times a week and sleep with it to track sleep. I have had it since last March. I fully charged my FitBit yesterday, it tracked my sleep and I synced it manually in the morning as I often do. (I turned off automatic sync to save battery life) At some point a few hours later it died completely--did not vibrate my wrist or anything. As I entered my lunch in the food log, I wanted to sync and noticed it had died... I have placed it in the charger and it won't charge or show me any sign of life.... help?
Best Answer01-23-2017 13:47
01-23-2017 13:47
Depending on how dead the battery is, and the current ca poo ability of the charging port being used, it might take an hour or two before the battery is charged enough to turn the unit on. Until then you will not see any sign of life.
Keep in it the charger.
Best Answer01-23-2017 14:02
01-23-2017 14:02
Thanks--it's been plugged in for 15 or so. I will keep waiting....
