03-07-2020 16:58
03-07-2020 16:58
Can Fitbit fix the issue with Treadmill distance calculation or remove the feature. Or give the option to adjust the results. This is crazy that for years people are asking and complaining about distances. If you cannot fix the stride on a treadmill allow me to put the decimal mile in.
Best Answer03-07-2020 21:54
03-07-2020 21:54
I manually log it.
You not covering an exact distance because you are not moving forward.
Also See this thread by MrMarv It explains it very well
Another good tread to read on treadmills
Wendy | CA | Moto G6 Android
Best Answer03-08-2020 07:30
03-08-2020 07:30
I understand the issue on distance because I am running on a treadmill vs running outside where the GPS function on the phone would accurately track the run. The issue is they need to fix the issue with the 3 axis movement tracking stationary running on a treadmill.
mill try to manually add the difference but if it doesn’t register on the daily total then it’s a waste of time.
