09-10-2016 15:45 - edited 09-10-2016 15:46
Okay, I know this is a long shot, and my particular problem might be related to my make/brand of car, but here goes nothing...
I owned a charge before. Never ran into that particular problem :
When I use bluetooth audio in my car (Toyota Venza), eventually the sound will start skipping and I need to cycle back to BT Audio (sometimes several times) for the issue to stop, but then the car display only shows "STREAMING AUDIO" and no other info.
To be fair I haven't tried to turn off continuous sync in the fitbit app, but I'd rather things not get to that.
Obviously, this doesn't detract from my enjoyement of the Blaze (nor my music!) but I'm curious to see if anyone else experienced the same thing.
Thank you,
Sébastien Décarie
09-19-2016 14:06
09-19-2016 14:06
Hello,
Finally, ever since I installed iOS 10 on my iPhone, the problem went away. So consider this thread solved 🙂
@Rich_Laue , thanks again for all your help 🙂
Seb
09-10-2016 15:59 - edited 09-10-2016 16:02
@SunsetRunner try telling the phone to forget the Blaze Classic, alternatively turn Blaze Classic off through the Blaze settings menu. As for as the charge it syncs through the Bluetooth LE, the same as the Blaze.
Where the blaze differs is that it also has Bluetooth Classic, for audio and music control, which is how the Phone connects to the car radio. A note about the iOS phone, it doesn't need the Bluetooth Classic at all, no need to pair.
09-10-2016 16:05
09-10-2016 16:05
@Rich_Laue Thank you, I'll tell my iPhone to forget the Blaze.
However, seems to be the issue might come back considering that the problem probably comes from using 2 devices to use bluetooth classic..?
09-10-2016 16:13
09-10-2016 16:13
09-10-2016 16:21
09-10-2016 16:21
@Rich_Laue True that, the car can control bluetooth audio the same way the blaze does ; pause, forward, reverse.
09-10-2016 19:36
09-10-2016 19:36
09-19-2016 14:06
09-19-2016 14:06
Hello,
Seb
12-13-2016 04:42 - edited 12-13-2016 04:44
I have the same problem, however with a different vehicle and an Android phone.
I have to turn my Blaze off when I am in the car, otherwise the phone is unusable for voice.
This only seems to have been apparent since the latest Firmware (or since I stopped using FitNotifications and changed to the new in-app Application Notifications feature)
03-27-2018 18:42
03-27-2018 18:42
I have the issue with a Samsung S8 and a chevy traverse.
Has been working fine since October. Suddenly this week, I cannot connect to my car bluetooth automatically......unless I uninstall the FitBit app......how can i fix this??
05-21-2018 10:44
05-21-2018 10:44
I have the same problem. Worked fine until last month. (April 2018) I have a GMC Acadia 2016. My phone won't connect to my car's bluetooth unless I delete my Fitbit app from my phone. Haven't found a solution to the problem yet...would like to hear of one!
05-21-2018 11:41
05-21-2018 11:41
Are you sure that you have to delete the app @hopijr.
Heave you tried with simply removing the tracker from the phones bluetooth
Have you tried with your tracker at least 30-50 feet away from the car.
05-21-2018 12:19
05-21-2018 12:19
Hi Rich. I thought I had tried that, but after receiving your response, I tried it again. I unpaired my tracker from my phone, turned my tracker off, and left it in the house. With the Fitbit app is installed on my phone, I went out to my car and cranked it. My phone connected to my car. Just to be sure, I tried it several more times and it connected to my car. But with both my tracker in the car and Fitbit app installed, my phone does not automatically connect to my car. I became suspicious that the problem with not automatically connecting was due to my Fitbit when I tried connecting while my phone was in safe mode. In safe mode, I was always able to automatically connect. By process of elimination, it came down to Fitbit. Thanks for any advice on resolving this issue.
05-21-2018 12:30
05-21-2018 12:30
05-21-2018 13:27
05-21-2018 13:27
If you tell the phone to forget the Blaze Claaaic iIwould think the radio would then connect to the phone. However this will also keep the Blaze from controlling music on the phone.
Or through the Blaze turn the Bluetooth classic off .
05-21-2018 17:23
05-21-2018 17:23
Bluetooth Classic is always off. I don't use it. Thank you. Can you think of anything else I can try?
05-23-2018 09:10
05-23-2018 09:10
Sorry not off hand. this doesn't make much sense. The phone as a bluetooth server should not care. I could see how connecting to two different Bluetooth speakers would cause conflict.
05-23-2018 09:15
05-23-2018 09:15
Try this page for troubleshooting
https://www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
I had to search your posts to figure out that you have an android phone.
Does it have Bluetooth version 4 or 5?
