06-10-2016 21:56
06-10-2016 21:56
The green LED lights on the back of my Fitbit Blaze are not blinking. They are lit...even though I shut it down. Anyone else have this problem or know how to solve it?
Best Answer06-10-2016 23:49 - edited 06-10-2016 23:54
When ypu say not lit, I'll assume they are not blinking?
What did you shut down? Usually when something is shutdown it is turned off, I'm not sure what your asking?
06-13-2016 07:38
06-13-2016 07:38
A warm welcome to the Forums @donnie3v. If the LED lights in the back of your tracker are not blinking, I recommend verifying if your heart rate feature is on or auto. If it is not, please put this option in on or auto by doing the following from your iOS Fitbit app:
1. Tap Account
2. Tap Blaze
3. Tap Heart Rate
4. Select "On" or "Auto"
5. Sync
If this doesn't work, then you can Restart your Blaze.
Hope this helps, let me know the outcome. ![]()
06-13-2016 08:46
06-13-2016 08:46
Best Answer06-13-2016 09:09
06-13-2016 09:09
A warm welcome to the Community @cg389. If you have already tried the steps I provided without success, feel free to contact our Support Team, since they have the proper tools to see what's wrong with your device. For a faster response you can contact them via phone or chat.
Let me know how it goes. ![]()
07-27-2018 07:16
07-27-2018 07:16
My green lights don’t blink...they are on solid green. Battery life is 1-2 days. Restarting Blaze does no good. Any thought?
Best Answer07-27-2018 16:37 - edited 07-27-2018 16:39
@Albstatter have you tried the shutdown command yet.
On the Blaze you will find it under setting.
If that doesn't help @AlejandraFitbit posted a link to support.
07-28-2018 07:10
07-28-2018 07:10
Best Answer07-28-2018 15:06
07-28-2018 15:06
What has support come back with @Albstatter?
