03-16-2017
22:51
19:25
DavideFitbit
03-16-2017
22:51
19:25
DavideFitbit
My Fitbit Blaze is still under warranty, where can I bring it to check the problems of Minutes not functioning correctly ? Please provid phone number and address in Hong Kong.
Moderator edit: format
03-17-2017 04:19
03-17-2017 04:19
It's great to see you around @ESL1. Can you please tell me which activity are you doing to earn active minutes? In the meantime, I recommend restarting your Blaze and test it. Also, you can take a look at our What are active minutes? article.
Hope to hear from you soon.
03-17-2017 09:50
03-17-2017 09:50
Hi Alejandra, I wrote you earlier regarding my Fitbit Blaze not recording Minutes correctly when I played 18 holes golf for over 4 hours and also when I set tracker on Exercise=> Walk for 3 hours. In both occasion, it always show 10-15 Minutes .
03-18-2017 09:44
03-18-2017 09:44
An Active Minute is not the same as a minute of activity. You need to be active with a certain pace and intensity in order for it to count as Active so it may be that this isn't being achieved. Certainly, when golfing, I'd have to question whether the level of activity would be high enough to register as an Active Minute.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
03-18-2017 19:28 - edited 03-18-2017 19:30
@ESL1To add to @MikeF post here is a bar chart of the way active minutes work. It needs a burst of 10 minutes at a minimum of 3 times your sleeping/resting BMR.
I would suggest you create an Activity Record from your PC's Dashboard via the Activity Log. The large stopwatch at the bottom of the view. This is a copy of your data and that way you can analyze your golf activity. I feel golf, being the way it is, there would not be 10 minute stretches of fast walking. I need to walk at 5km/hr for 10 minutes to achieve a 10 minutes of Active Minutes or an Activity that gets my HR up for the minimum of 10 minutes.
When you create the record just click on the very small stopwatch next to the description and then click Calories for the chart
Here is an example but ignore the green line because I was analyzing Very Active Minutes as well which is 6 times your BMR. So everything on or above the orange line with a continuous 10 minutes or more.
03-18-2017 21:31
03-18-2017 21:31
Thank you Colinm39 .
03-18-2017 21:33
03-18-2017 21:33
Thank you MikeF.
03-18-2017 22:01
03-18-2017 22:01
@ESL1I'm glad we could assist... This is a great Community when we have the UK and Australia helping Hong Kong.
Another time saving tip for you.. When you create a post, at the very start you use the @ key and a list of the contributors to this topic will appear. You click on the one you wish to acknowledge or ask....so I will send a message to @MikeF and wish him a pleasant morning when he wakes... and you can make reference through the post.
Enjoy you evening.. it is 32oC in Melbourne..
