10-01-2016 18:28
10-01-2016 18:28
I got the blaze today and i was able to do the setup and update but now it wont charge i have tried everything from different ports to resetting and different chargers the charger worked fine on my brother but will not work with mine
Best Answer10-02-2016 00:59
10-02-2016 00:59
Have you tried cleaning the contacts with alcohol and a q-tip?
Best Answer10-02-2016 09:35
10-02-2016 09:35
Best Answer10-02-2016 12:02
10-02-2016 12:02
10-02-2016 15:22
10-02-2016 15:22
Best Answer10-03-2016 07:41
10-03-2016 07:41
Hi there @delunafd. Good to see you in the Forums!
You mentioned that you tried your charger on your Brother's tracker. Did you try the other way around? His charger on your tracker just to be sure.
If that doesn't work, it could be something directly with the tracker itself, so as @Rich_Laue said, you can feel free to reach out to the Support Team and they will be happy to help you out and get you back on track.
Let us know if you need more help with this.
