04-17-2017 14:43
04-17-2017 14:43
I plugged my blaze to the laptop I get it right way into the charging box and no battery pops up saying that it charging what do I do?
Best Answer04-17-2017 15:37
04-17-2017 15:37
Same problem & it just came out of the box
Best Answer04-18-2017 12:17
04-18-2017 12:17
If this is a fitbit out of the box, that displays www.fitbit.com/setup then you are correct, there will be no battery icon sonce the tracker is not setup.
Now that the tracker is plugged in and charging.why not provede to set it up?
