Does the screen turn on when tapping onto when out the charger? If it does, from the clock screen can you scroll once to the right on the tracker? There's a battery icon in the upper left corner, indicating the current charge.
Thank you very kindly
PS: The screen doesn't stay on, it always goes in standby after x seconds (it's working in the background, just the screen dims)..
The screen is shown when tapping onto, pressing the left button, or turning your precious wrist towards you when quick view setting is turned on.. (unless the device is turned off or no battery power left).. ![]()
Hello @Skylyn86 welcome to the Fitbit Community! If your Blaze's display is not turning on I recommend to restart your tracker. If after this your tracker is not working properly, contact customer support, they can take a look at your tracker's back-end information and provide you the troubleshoot you need to get back on track! @SunsetRunner thanks for your cooperation! 😉
Let me know how it goes!
It is health that is real wealth and not pieces of silver and gold! Share your story!
