Hey,
Can I go running with my Blaze without using my smartphone? So first before running I connect with bluetooth and load some Google Music Play numbers in Blaze (?). So then I disconnect bluetooth just before running, and leave my smartphone at home.
Will I still can use some music via a wireless headphone connected with my Blaze while running?
Thanks!
Best Answeryou can do that, but the music comes from the smartphone. So... you can run but you can't listen to music without the phone firmly attached to your body. An apple watch can do that, but the battery life is only a few hours.
a good suggestion however, for some new model that will allow that , sorry
Best AnswerI also reccomend entering your stride length if you are going to run without GPS....
https://help.fitbit.com/articles/en_US/Help_article/How-do-I-measure-and-adjust-my-stride-length
I used one time around my block... measured with GPS first... then calculate / enter stride length- then retest... I was able to get the Blaze to be dead on after some trial and error.
